TwinTurbo.NET: Nissan 300ZX forum - When seals are worn, engine oil is burned out into exhaust
Subject When seals are worn, engine oil is burned out into exhaust
Posted by qcsolo on July 14, 2006 at 12:07 PM
  This message has been viewed 52 times.
In Reply To direct testing is if you don't have restrictors the seals posted by Crim on July 14, 2006 at 10:11 AM
Message manifold with usual blue smoke at exhaust ends. There is radial and lateral play on the driver turbo at least and i have burned over one liter of Motul 0W-40 oil within 200 miles without evidence of blue smoke at exhaust ends. I"m using braided lines and hose adapter use at turbo inlet hole should have a .090" hole dia approx. or similar to the turbo core oil inlet bore.
